Shows the NTP key index number, trusted or non-trusted, authentication type, and encrypted key string.
N/A.
N/A.
N/A.
The following command shows the NTP key index number, trusted or non-trusted, authentication type, and encrypted key string:
# show ntp key Key Index Trusted Auth Key String (encrypted) ================================================================ 100 No MD5 67:74:7d:78:6f:6c:67:5b:33 200 Yes SHA-256 23:24:6c:35:4a:35:79:74:65
This command was first available in ExtremeXOS 12.7.
SHA-256 information was added in ExtremeXOS 30.4.
